Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ansys Fluent’s GPU Solver uses RNG to converge? › Reply To: Ansys Fluent’s GPU Solver uses RNG to converge?
November 23, 2023 at 4:18 pm
Hi, our GPU solver has been tested and validated with several benchmark cases so I am confident on the consistence of results.
What are you monitoring? Are you cheching the Drag on a specific surface. Can you monitor the final value, at conercence instead of itereration evolution.
Are you experience such behavior also with other casese? Can you check with the lastest version 23R2 if it happens again?
Thanks
Luca
