Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Simulation of a Microstrip Line in Ansys HFSS › Reply To: Simulation of a Microstrip Line in Ansys HFSS
AncS
Hello Qian,
Thank you for reaching out to the Ansys Learning Forum.
This error occurs if both the top and bottom conductor sheets are shorted. Please see if 'Auto Open Region' is enabled in the solution type window. If not, an explicit radiation box should be added to the model because the default material in Ansys HFSS is PEC.
You may find this thread helpful - Port Refinement, process hf3d error: Too few conductors were found on port1 (ansys.com)
Best regards,
Anchal
