Ansys Learning Forum Forums Discuss Simulation Optics Changing constructed objects parameters Reply To: Changing constructed objects parameters
Niki Papachristou
Hi Oren,
Thank you for contacting us. There's 2 ways to change the number of frequency points in a monitor:
  1. Globally in the "Monitors - Global properties"
  2. Locally in a specific monitor.
When using the "Global properties", you will set the number of points for all monitors in the simulation, unless you check "override global monitor settings" in the monitor properties:
With this, you can set the number of points for a specific monitor. I hope that was helpful, let me know if I can be of further assistance.
Please note that this is the optics forum and not the photonics where lumerical related question are posted. For you next lumerical question please post at: Ansys photonics forum
Kind Regards,
Niki
