Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Calculation of a multistage centrifugal pump › Reply To: Calculation of a multistage centrifugal pump
javat33489
I looked thanks.
Tell me, when calculating wheels, what fields need to be passed? Speed and pressure are accurate. And what else?
My goal is to ultimately monitor the pump’s pressure characteristics, efficiency and cavitation.
I will model one wheel. There will be a rotating domain around the wheel. The two faces of this domain will be the input and output of the wheel, where I will substitute the fields.
