Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Connections and Process › Reply To: Connections and Process
Jeffrey Lailey
Hi Akshay,
Thank you for your reply. That is what I have started to try. In order to do this, from tutorials I have done, it looks like I need to move all the line bodies so they are touching and then offset them to their original position? The line bodies are supposed to be welded all the way along where they connect to the surface bodies, do you know if this will this be possible with connections? The other issue I ran into with making all the line bodies on the same plane is that I have two vertical line bodies that are parallel with each other so when I make them on the same plane they are in the exact same position. Any help is appreciated.
Thanks,
Jeff
