Ansys Learning Forum Forums Discuss Simulation General Mechanical Water Cooling Analysis Reply To: Water Cooling Analysis
ErKo
Hi
Perhaps this is of help.
/forum/forums/topic/transient-thermal-analysis-of-a-cup-that-holds-hot-fluid/
Bu the IC command needs to go on the nodes of the body so that named selection (COFFEEBODY) needs to be converted to a nodal named selection.
Also in the above post see the limitations with this analysis.
All the best
Erik
