Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with UDF initializing › Reply To: Problem with UDF initializing
November 21, 2023 at 3:16 pm
Federico
So the problem might be with your mass flux function. See if your able to implement it in a simple model. If that doesn't work, the UDF is the problem; if it works, the problem is with your case setup.
