Ansys Learning Forum › Forums › Discuss Simulation › Fluids › solidification and melting › Reply To: solidification and melting
November 21, 2023 at 2:58 pm
OK, so just the carrier fluid changes phase.Â
The solidification/melting model works by freezing flow in cells below the solidus temperature. So, for Eulerian you can possibly use phase interaction or material properties to do this. Equally, at 11microns the glass beads may follow the flow, if so, do you need to include them? Or if the volume fraction is low maybe DPM?Â
There are options, but you need to do some more reading to understand how/what the solver does to then apply that to the specific example you wish to model.Â
