Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Water Cooling Analysis › Reply To: Water Cooling Analysis
armin.abedini
Hi Akin,
If you have access to Ansys Learning Hub (ALH), a similar problem has been solved using commands (APDL) utilizing SURF152 elements in Workshop #1 of Module 7 in Ansys Mechanical Heat Transfer course:
Structures | Heat Transfer - Ansys Mechanical Heat Transfer (sapjam.com)
