Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Parallel resonace coil array › Reply To: Parallel resonace coil array
Miguel Gonzalez
My end goal is to obatain S21 from the input lumped port to the output lumped port.
  1. Yes , I need to keep the coils connected in parallel. I connected the coils in parallel using polylines , however I would like to know if there is a way to connect them in parallel by using a setting or something to avoid drawing this polylines.
  2. I ensure they are couple by calculating the mutual inductance by using the Z12 parameter between the input and output port
