Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Node merge causes negative Jacobian › Reply To: Node merge causes negative Jacobian
erik.kostson
Hi
Node merge has most likely made some elements unsuitable for FE (hence Jacobian error).
If the geometry is just touching between them, and the wires are bonded then try shared topology. See below
https://www.youtube.com/watch?v=aqAYnZXoUHQ
All the best
Erik
