Ansys Learning Forum Forums Discuss Simulation Fluids BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES error Reply To: BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES error
That looks to be a node failure or similar, so not directly linked to the solver convergence. Can you check you're not triggering any autosave or image generation, and if so switch it off. If the model then runs OK check disc access as that can cause problems if you can't write to disc.Â
