Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How should the viscosity of particle be set when using non-Newtonian fluids? › Reply To: How should the viscosity of particle be set when using non-Newtonian fluids?
November 21, 2023 at 3:49 am
If according to my definition above, the viscosity of a non-Newtonian fluid is a function of shear rate, then what about DPM particles? How should shear rate be expressed for DPM particles? By the way, do particles have the concept of shear rate?
