Ansys Learning Forum › Forums › Discuss Simulation › Platform › Failed to validate credentials in RSM › Reply To: Failed to validate credentials in RSM
MangeshANSYS
Please check the Software Guides for Ansys when using the cluster in question. Perhaps is is necessary to load a module so Ansys becomes available in yoru user login before you can run Ansys ?
you can try adding the relevant module load command to your .bashrc file or to this file /ansys_inc/v231/Config/tools/linux/rsm_env_profile
