Ansys Learning Forum Forums Discuss Simulation Photonics ‘gloabl source shutter’ in Lumerical CHARGE Reply To: ‘gloabl source shutter’ in Lumerical CHARGE
Niki Papachristou
Hi Sungmin,
Thank you reaching out to us! I believe for your case you are correct you don't need the shutter and you can disable it. You just need to make sure the contacts in boundary conditions are changed accordingly vs time (V vs t). You should be able to see the evolution of n and p as the results are reported separately for each voltage.
I hope that was helpful, let me know if I can be of further assistance.
Kind Regards,
Niki
