Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Conjugate Heat Transfer in CFX with “No-Solid” approach › Reply To: Conjugate Heat Transfer in CFX with “No-Solid” approach
November 20, 2023 at 2:04 pm
thanks. I have a case where I have to simulate flow inside a pipe and consider fluid, pipe wall (steel) and then insulation material. I am confused between the thin wall approach and with-solid approach.
