Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with UDF initializing › Reply To: Problem with UDF initializing
Federico
I would recommend starting simple and working your way in complexity as your able to run the UDF.
Start with setting a constant mass flow rate at the inlet and see where this fails. You can also insert some debugging messages in your UDF for troubleshooting.
