Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How should the viscosity of particle be set when using non-Newtonian fluids? › Reply To: How should the viscosity of particle be set when using non-Newtonian fluids?
November 20, 2023 at 12:59 pm
Try this: create an expression, make it input parameter. Both the fluid and particle viscosities has the common "Input parameter" option.
Also, for particle viscosity from UDF, DPM_PROPERTY macro is required.
