Ansys Learning Forum Forums Discuss Simulation Electronics How to simulation no- load and full load PM generator Reply To: How to simulation no- load and full load PM generator
phuonganhlovely.me
Thank you Harinath Vudumula.
I appreciate the way you explained the steps for the 2 simulation cases.
I also have some questions I want to clarify.
1. solution (1): how to determine the value of Vpeak?
2. Solution (2): why the load torque is 4.7746 Nm while I want to apply 5 Nm (load torque) (when I set the moment of inertia value the speed also increases) and Why doesn't the voltage equation have a delta variable?
3. solution (3): how can I connect the coil in the star (do you mean using group winding?)
thank you so  much
