Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Insert a heat generation rate function as a heat source in a thermal simulation › Reply To: Insert a heat generation rate function as a heat source in a thermal simulation
ashish.khemka
I think you will need to apply heat generation on elements via BFE command.
Ashish Khemka
