Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Error with SN curve › Reply To: Error with SN curve
November 19, 2023 at 7:21 pm
Thanks for the answer. Yes, I will see the high stress area through the d3plot or use *DATABASE_D3MAX and *DATABASE_MAX_SOLID. It's not a problem.
Once I see these zones, how can I remove elements whose values cause singularity or undue tension?
