Ansys Learning Forum Forums Discuss Simulation Electronics How can a transistor be inserted into Circuit Design? Reply To: How can a transistor be inserted into Circuit Design?
Byeongin Lee
Thank you!! I found a way to add the emitter. Can you confirm if this method is correct?
  1. right-click on the imported n-port.
  2. Edit symbol
  3. pin location
  4. reference->show common reference port.
Is it right?
