Ansys Learning Forum Forums Discuss Simulation Electronics How can a transistor be inserted into Circuit Design? Reply To: How can a transistor be inserted into Circuit Design?
Praneeth
Hi Byeongin Lee,
Thank you for reaching out to the Ansys Learning Forum.
It is possible to insert the regular 3 terminal BJT in Ansys Circuit. Please follow these steps:
  1. Make sure that the component libraries window is visible under the "View" menu.
  2. Select "Groups"
  3. You will find "BJT" as the first element. Select it and paste it on the schematic to insert.
  4. Double-click on the inserted element to open the properties window containing the defining parameters, component and other related tabs. Go through the details for more information.
Kindly do note that the Ansys Circuit has different component types under BJT and use as per the requirement. Detailed information about these elements is available under the Help menu as well as the properties window (Component tab - Info field).
Best regards,
Praneeth.
