Ansys Learning Forum Forums Discuss Simulation Fluids Aerodynamic coefficients for a multi-part wing airfoil Reply To: Aerodynamic coefficients for a multi-part wing airfoil
C N
Hello Nicola,
It depends on what boundary conditions you are going to set for the fixed and moving parts. If the boundary conditions you are going to apply for the moving part along with the fixed part is the same then I suggest you to select the entire parts and name it as airfoil if not then select only the fixed parts and name it as airfoil in named selections.
I hope this helps you in your simulation.
Thanks,
