Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Steady state thermal analysis Simulation of LED › Reply To: Steady state thermal analysis Simulation of LED
November 17, 2023 at 9:43 am
Hello Shubham,
The difference in temperature is very small. I would recommend you to check the boundary condition and what type of radiation model you have used. To improve your accuracy I recommend you to follow the user guide link for setting up appropriate radiation model for your application. Kindly check this.
15.3. Modeling Radiation (ansys.com)
I hope this helps you in your simulation.
Thanks,
