Ansys Learning Forum Forums Discuss Simulation General Mechanical Insert a heat generation rate function as a heat source in a thermal simulation Reply To: Insert a heat generation rate function as a heat source in a thermal simulation
Ashish Khemka
Hi Bond,
If you know the heat generation locations at different locations then you can use the External Data module to apply heat generation on a deformed model. I am not sure on how you can do the same based on stress and strain.
External Data (ansys.com)
How to access the ANSYS Online Help
Ashish KhemkaÂ
