Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › HFSS : How to get characteristic impedance using terminal network solution? › Reply To: HFSS : How to get characteristic impedance using terminal network solution?
Praneeth
Hi Jungwoo Lee,
Thank you for reaching out to the Ansys Learning Forum.
Please use modal lumped port for obtaining the characteristic impedance if you are using the latest version of AEDT. If you are not using the latest version, please use wave port excitation in the Modal solution type to get the characteristic impedance. For detailed information please go through the HFSS help document.
Best regards,
Praneeth.
