Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Error in CHARGE › Reply To: Error in CHARGE
November 17, 2023 at 12:22 am
Alisa Bannaron
Hi Amrita!
There is no material assigned in between triangles. With this setting, there was no problem running in the y-axis, only in the z-axis that I couldn't run the simulation. Should I add the other object and set as air to fill in between each triangles when simulating in z-axis?
I tried changing the min edge length while maintaining the max at 1 um, the same error still showed up.
Alisa
