Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Energy Equation Divergence ansys divergence › Reply To: Energy Equation Divergence ansys divergence
Hellom
Thank you for your answer,
This is the Report quality:
Mesh Quality:
Minimum Orthogonal Quality = 3.24228e-07 cell 86742 on zone 6 (ID: 1279410 on partition: 2) at location ( 1.00402e-02 7.34195e-03 3.86050e-03)
(To improve Orthogonal quality , use "Inverse Orthogonal Quality" in Fluent Meshing,
where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
Warning: minimum Orthogonal Quality below 0.01.
Maximum Aspect Ratio = 1.34494e+03 cell 296109 on zone 6 (ID: 1115234 on partition: 2) at location ( 5.03466e-02 1.06909e-03 -8.35610e-03)
Fluent can try to improve the mesh quality via the TUI command
/mesh/repair-improve/improve-quality
Domain Extents:
x-coordinate: min (m) = -9.000000e-02, max (m) = 1.500000e-01
y-coordinate: min (m) = -1.000664e-02, max (m) = 1.000000e-02
z-coordinate: min (m) = -1.000000e-02, max (m) = 1.050000e-02
Volume statistics:
minimum volume (m3): 8.992539e-16
maximum volume (m3): 6.769667e-10
total volume (m3): 9.907077e-05
Face area statistics:
minimum face area (m2): 7.985135e-11
maximum face area (m2): 1.673634e-06
Checking mesh.....................................
Done.
