Ansys Learning Forum Forums Discuss Simulation Fluids Define_DPM_scalar_update Reply To: Define_DPM_scalar_update
ll00023
This is the memory for 88 cores. the memory is enough for simulation.
If I use Define_dpm_scalar_update, does the tp stores all the particle parcel info?
I have tested the code in URANS case of EBU example. but it didn't work in my URANS and LES case.
