Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Named Selection error between Spaceclaim and Mechanical › Reply To: Named Selection error between Spaceclaim and Mechanical
November 16, 2023 at 2:32 pm
In 2023R2, I am able to import curve points from extracted beams into Mechanical. Which version are you using?
Make sure all vertices are attached to beams that have cross section. If the curves do not have cross section assigned, those are not imported into Mechanical
If this doesnt work, can you use worksheet named selection in Mechancial?
Example worksheet named selection to pick vertices from beams and then filter based on location
