Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Cogging torque › Reply To: Cogging torque
November 16, 2023 at 2:20 pm
Hello Jaafar,
Please check the below points in your model.
- rotate the rotor at a speed of 1deg per second, excite the coil with current =0A or non model the coils
- improve the meshing in the airgap ,the rotor outer diameter and stator inner diameter area
- improve the time step to capture the torque variation
