Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error Message › Reply To: Error Message
November 16, 2023 at 11:31 am
Saumadeep Choudhury
Clicking on the "Show 7 Messages" option should show you the messages. But if that is not the case, try resetting the App Data:
Follow the steps below to reset ANSYS Appdata:
- Exit ANSYS, if you are using it currently.
- Go to Start > Run
- Enter %APPDATA%
- A folder explorer window will open
- Open the Ansys folder. Look for the Ansys version you are using, for example, v221, and rename it to v221_Old
- Launch ANSYS and refresh the project
Saumadeep
