Ansys Learning Forum Forums Installation and Licensing Ansys Products Error “unexpected end of file” when running Lumerical 3D FDTD in HPC Linux Reply To: Error “unexpected end of file” when running Lumerical 3D FDTD in HPC Linux
Lito
@Jordi Lopez Leyva,
From the command you provided,
/.../mpiexec -n 4 -host tue-login002 -env HOME /.../test /.../fdtd-engine-mpich2nem -t 1 /.../Nanobeam.fsp
Are you running the simulation remotely from a Linux machine to another Linux machine, 'tue-login002' ?
Are you able to log in to the Linux machine, 'tue-login002', and run it directly from there (not remotely)?
i.e.
/cm/shared/apps/lumerical/2023-R1.1/mpich2/nemesis/bin/mpiexec -n 4 /cm/shared/apps/lumerical/2023-R1.1/bin/fdtd-engine-mpich2nem -t 1 /home/”MyPath”/Lumerical/test/Nanobeam.fsp
Otherwise, try the command below, without the '-env HOME' options for the MPI. Let me know if the issue persists even though the simulation ran successfully.
/cm/shared/apps/lumerical/2023-R1.1/mpich2/nemesis/bin/mpiexec -n 4 -host tue-login002 /cm/shared/apps/lumerical/2023-R1.1/bin/fdtd-engine-mpich2nem -t 1 /home/”MyPath”/Lumerical/test/Nanobeam.fsp
