Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Facet Body or Solid Body Enclosure › Reply To: Facet Body or Solid Body Enclosure
Federico
This tells me that your faceted geometry is not clean.
You can still try to proceed with the mesh. If not with the Watertight Geometry workflow in Fluent Meshing, with the Fault Tolerant Meshing workflow.
