Ansys Learning Forum Forums Discuss Simulation Fluids Diverging Results with density based solver Reply To: Diverging Results with density based solver
ae22b001
Yes but The bigger problem is that after I get the steady state solution, I simply changed it to transient with a timestep of 1e-5 (nothing else is changing). Ideally it shld converge instantly at every timestep, but after a few iterations it started slowly diverging.
