Ansys Learning Forum Forums Installation and Licensing Ansys Products Error at Node -: Normalized key of – is out of range Reply To: Error at Node -: Normalized key of – is out of range
Luca B.
Hi , cortex errors are typically related to Graphic interface. Anyway the error message seems to be memory related during your parallel run. Are you working with UDF? verify that it is written for parallel run.
If you can arise a support request we can furhter analyze your model.
Luca
