Ansys Learning Forum Forums Discuss Simulation Fluids Facet Body or Solid Body Enclosure Reply To: Facet Body or Solid Body Enclosure
Federico
When you convert the car into a solid, can you do a geometry check to verify that it is free of errors? Right click on the solid in your structure tree and select Check Geometry.
