Ansys Learning Forum Forums Discuss Simulation Fluids #f error when importing from spaceclaim – also can’t import tgf – 2023 r1 Reply To: #f error when importing from spaceclaim – also can’t import tgf – 2023 r1
Federico
it is possible that you may have some corrupted files in your .ansys temp folder. Can you try deleting or renaming these folders?
1) Open Windows File Explorer and type
%temp%
in the path bar.Search for the folder ".ansys" and rename it to a different name (any other name will be OK)
2) Instead of %temp%, type
%appdata%
and search for the folder "Ansys". Rename it to any other name. This should force ANSYS to recreate these folders and avoid any corrupted file that was triggering the error.
