Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Error “unexpected end of file” when running Lumerical 3D FDTD in HPC Linux › Reply To: Error “unexpected end of file” when running Lumerical 3D FDTD in HPC Linux
November 15, 2023 at 10:10 am
- Which Linux distro and version are you running on?
- CentOS Linux release 7.9.2009 (Core)
- Which version of Ansys Lumerical are you using?
- Ansys Lumerical 2023 R1.1
- Do you run/submit to a job scheduler using a script?
- No script, just command
- Does the simulation run successfully?
You can check the “simulationfilename_p0.log” file if the simulation is completed.- Simulation did complete succesfully
- Can you open the simulation on your local desktop to view the results?
- Yes
- Are you using the bundled MPICH2 to run the simulation?
- I’m indeed using the bundled MPICH2 from the Lumerical installation
- Please send the sample execution line you used to run the simulation on the cluster.
- /cm/shared/apps/lumerical/2023-R1.1/mpich2/nemesis/bin/mpiexec -n 4 -host tue-login002 -env HOME /home/”MyPath”/Lumerical/test /cm/shared/apps/lumerical/2023-R1.1/bin/fdtd-engine-mpich2nem -t 1 /home/”MyPath”/Lumerical/test/Nanobeam.fsp
