Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Contact After Failure › Reply To: Contact After Failure
Jim Day
You've set SURFATYP to 3 so that means SURFA is interpreted as a part ID. To put multiple parts on the slave side, you must set SURFATYP to 2 and then you can set SURFA to a part set ID. A part set is defined using *SET_PART.
