Ansys Learning Forum Forums Discuss Simulation General Mechanical Steady State thermal and Static structural Analysis – Error regarding Reply To: Steady State thermal and Static structural Analysis – Error regarding
ANSYS EXPLORER
Dear Peteroznewman,
Thank you for yiur swift reply.
I performed the modal analysis as suggested and found first 3 modes are equal to zero value. Surprised to see these modes are linked to main parts like shells and nozzle connections which are not having proper connectivity.
Marked up sketch which are having loose parts (3 Nos) from modal analysis attached. Then i took a action to connect these parts with adjoining parts using JOINT in workbench. But, No sucess, as it is not getting scoped with adjoining faces when we select the respective face ( reference face and mobile face) of component for JOINT. What could be the reason ?. Is it due to meshing with shared topology ? so i am not able to connect through JOINT?.  Please advise the way out. Thank you.
Regards
AE
