Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Simulation of a Tensile Test to validate material properties › Reply To: Simulation of a Tensile Test to validate material properties
armin.abedini
Hi Henrique,
No problem. As far as I know, curve fitting with these options is currently not available in Mechanical GUI, but if you look up the format of power-law or Voce equations, they have simple forms and curve fitting can be done in Excel or using other codes. You may look that up online to find some good information.
