Natalie Berreth
Hi Armin,
In the picture above left, the outer ring is held against displacement in a horizontal direction. At the bottom right, the ring is held by a clamp. The bearing is held against rotation in all directions and against horizontal displacement as well as displacement in the plane.
I have taken the interaction between the ring and the bearing into account by means of a contact surface with friction.
