Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Fatigue Analysis with Time history Input › Reply To: Fatigue Analysis with Time history Input
faycal.abdoun59
Thank you so much for you explanation.
So, to check the model :
I switched the load to Fy=1N and I load the Fy history data file :
I get a life of 47 585 Cycles. But my damages are all over 1, they should be less than 1.
How can I use these damage results to determine after both analysis (with fy and fz) to determine the life in cycles using Miner's rule ?
In Apdl script I had a table with damage less than 1 and I add whole node damage to get the life.
