Ansys Learning Forum › Forums › Kampus Merdeka Belajar › The solver engine was unable to converge on a solution for the nonlinear problem › Reply To: The solver engine was unable to converge on a solution for the nonlinear problem
November 5, 2023 at 10:50 pm
Raihan Lutfianto
Hi Arif. In case the same error happens in the future. Please check for nonlinearities in your model (contact, material, and large deformation). Also, make sure you have set the auto time stepping to ON and set appropriate substeps.
