Ansys Learning Forum Forums Discuss Simulation Fluids Simulate Thermal Equilibrium Using ANSYS Fluent Reply To: Simulate Thermal Equilibrium Using ANSYS Fluent
sebastian.maluenda.m
The tutorials that I have been able to study do not mention much the cooling of an object or system, however, I will see if the User Guide provides a solution to simulate the PCM through a Mechanical Analysis. As for buoyancy, it is talked about in the tutorials, so I will take the advice into consideration and add it to the analysis.
