Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Accurate Position of dipole source in multi quantum well structures › Reply To: Accurate Position of dipole source in multi quantum well structures
November 4, 2023 at 12:27 am
Kyle
Hello, when we use a dipole source to represent an emissive structure in FDTD, we place the source where the photons are being emitted from. I would just place the source in the middle of the MQW structure, the same as the non-MQW case. If you're unsure, you could also try running the simulation several times with the source placed in a different emissive layer each time to see if the result changes.
