Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Surface energy of solid materials › Reply To: Surface energy of solid materials
November 3, 2023 at 1:54 pm
You can try rasing the temperature of the solid either by fixing the temperature of the solid to a high value or applying the thermal BC (temperature or heat flux) to the solid wall to a higher value.
