Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › APDL Node Stress and ID issue › Reply To: APDL Node Stress and ID issue
November 3, 2023 at 10:43 am
danielshaw
NSEL,S,CORNER should select the corner nodes and *GET should work on the selected set. So, using selection logic and *GET should enable to access information from a subset of the mdoel. *VGET works on the entire database. It does not work only on the selected set. To use *VGET acess a subset of the model, you need to use a masking vector *VMASK.
